th_fir100
Fir100 filter.
th_fir100(xvect, yvect, debug_flag)
Arguments
xvect
The time vectors (seconds).
yvect
Response vectors to be filtered (any units).
debug_flag
Optional argument. Flag to turn on debug mode (points to message log). Default is off.
th_fir100(p1w1c1.x, p1w1c1.y)
Fir100 filter is a low−pass filter, which means that high frequencies are filtered.
This filter is mainly used for biomechanics (Thorax Trauma Index). The filter is roughly of the same type as SAE filters.
Equivalent filter in TH++ is: LOW PASS Fourier
