getcwd
Returns the path for the current working directory. If you switch directories in the console or when loading files, the current working directory path will follow.
getcwd()
Input
N/A
Enter the following Templex statement in the Notes panel, Text tab and click Apply:
{getcwd()}
The current working directory, C:/Users, is displayed as the note.
If you switch directories in the Console, the current working directory will also change in the note if you click Apply in the Text tab:
N/A
