Resultsブラウザ
Use the Resultsブラウザ to review and manage results and plots.
The Resultsブラウザ contains a detailed view of result resources and existing plot definitions, and conveniently provides access to a number of actions. It can be accessed several ways:
- Automatically after a result file is imported
- By double-clicking Results or Plots in the Modelブラウザ.
- From the Post ribbon, by clicking the Results
tool.
図 1.
Each imported file is shown under the main result root as a resource.
Each load case (and simulation step) is listed under the pertinent resource it belongs to.
Use the Resultsブラウザ to:
- Update the current load case and step by double-clicking a new load case.
- Create a derived load case by right-clicking on any result or load case.
- Display or clear a plot by clicking on its icon.
- Modify plot definitions using the エンティティエディター.
