Export a HDF5 File
- Import the model and result file in HyperMesh.
- From the メニューバー, click Aerospace > Export > HM-HDF5.
- Select the export directory path.
Select the Schema Type.
Nastran is the default. If you select custom you can select a custom Schema File.
- Use the Elements Selector to select elements from the model.
- Select the subcases, if available, from the Subcase List.
Click Export.
The HDF5 file is exported.
- Click Close to close the tool.
