SimulationParameters
Class SimulationParameters()
SimulationParameters(parent='MODEL', name='simPara', label='SimPara')
Model simulation parameters.
Keyword Arguments
| Argument | Data Type | Description | Default |
| h3d_stress_option | Enum | Stress format in H3D file. One of None, Tensor or Direct. | Tensor |
| dzero | Double | Output displacements less than this value are set to be equal to zero. | 1e:10 |
| implicit_diff_tol | Double | The tolerance for implicit differential equations (for example Contol_Diff when is_implicit=true). | 1e=6 |
| init_pos_mrf | String | Defaults to ''. * end_time (Double) : The simulation end time. Defaults to 5. * write_mrf (Enum) : The result are written to an mrf file when true. One of TRUE, FALSE. | TRUE |
| no_req_id | Bool | The REQ/id is not appended to output when true. | False |
| harwell_lib | String | Defaults to 'MA48'. * write_h3d_end_time (Double) : The end time for h3d export. | 0.01 |
| log_option | String | Defaults to 'Overwrite'. * write_abf (Bool) : Plot results are written to an abf file if true. | True |
| prefix_body_label | Bool | Prefix output label for force output on body. | False |
| export_mdl_snapshot | Bool | A copy of the the mdl model as submitted to the solver is saved if true. | TRUE |
| analysis_type | Enum | The simulation type. One of Transient,Static,Quasi:static,Assembly,Linear, Static+Transient,Static+Linear,User Control. | Transient |
| plt_angle | Enum | The format for angular results. One of YAW_PITCH_ROLL, EULER_ANGLES. | YAW_PITCH_ROLL |
| write_log | Enum | A log file is written if true. One of TRUE, FALSE. | TRUE |
| write_h3d_start_time | Double | The start time for h3d export. | 0.01 |
| contact_temp_warning | Bool | Defaults to False. * default_run_dir (File) : | '' |
| inc_geom_non_lin | Bool | The geometric stiffening effects are included if true. | True |
| print_interval | Double | The time interval between two subsequent exports of the results to the output files | 0.01 |
| plot_unique_time | Enum | The result data per time output in the ABF and PLT files when there is more than one result available at a given time. One of FIRST, LAST, ALL. | LAST |
| flex_vel_acc_output | Bool | The velocity and the acceleration output for flexible bodies during a MotionSolve run when True. | False |
| use_h3d_start_time | Bool | Use the start time of writing results into an .h3d file when True. | False |
| h3d_format_option | Enum | The H3D file format. One of Modal, Nodal, Auto. | Auto |
| switch_on | Bool | Write debug information when True. | False |
| azero | Double | Lower threshold for output accelerations, they are set to zero below this. | 1e:10 |
| stat_anim | Bool | An animation is generated at each iteration (use with single Static simulation only) when True. | False |
| fzero | Double | Lower threshold for forces, they are set to zero below this. | 1e:10 |
| dsa_type | Enum | Need input. | 'NONE' |
| write_h3d | Bool | An animation file is written in .h3d format when True. | True |
| use_run_panel_values | Bool | Set to True when a simulation script exists in the model in the form of Template or CommandSets. Setting this True prevents MotionView from exporting the Simulate command (Simulation type, End time, and Print Interval) from the Run Solver panel to the solver deck. | True |
| use_init_pos_mrf | Bool | Defaults to False. * use_h3d_end_time (Bool) : If true, h3d results will be written up to h3d_end_time. | False |
| capture_max_pd | Bool | An extra output is introduced between two time steps when the penetration depth is larger than both of the time steps when True. | True |
| write_h3d_increment | Int | The increment at which h3d results are written out. | 1 |
| constr_tol | Double | The accuracy to which the system configuration and motion constraints are to be satisfied at each step. | 1e:10. |
| num_threads | Int | Number of CPU cores to be used when multiple cores are available. This is particularly helpful in parallelizing computations in the case of Contact simulation. | :1 |
| contact_gra_output | Bool | Contact force vector animation in the .h3d file when True. | True |
| vzero | Double | Lower threshold for velocity, they are set to zero below this. | 1e:10 |
| write_tab | Bool | Defaults to 'TRUE'. * h3d_strain_option (Enum) : The strain format in H3D file. One of None, Tensor. | 'Tensor' |
| write_maf | Bool | A maf file is written which can be loaded as a model in HyperView to view results with .mrf when True. | False |
| write_plt | Enum | A plt plot file is written when TRUE. One of TRUE, FALSE. | 'TRUE' |
| write_oml | Enum | Writes the A, B, C and D matrices that are calculated in simulink MDL format when YES. One of YES or NO. | 'NO' |
| write_simulinkmdl | Enum | Writes out the A,B,C and D matrices that are calculated into a file that can be read in by Altair Activate/Compose when YES. One of YES or NO. | 'NO' |
| anim_scale | Double | The animation scale. Used for linear analysis to set the scale factor for the modal animation. | 1 |
| write_eig_info | Enum | Writes the eigenvalue and eigenvector data to a .eig file when YES. One of YES, NO. | 'YES' |
| write_matlabfiles | Enum | Writes out the A,B,C and D matrices that are calculated into a file that can be read in by MATLAB when YES. One of YES, NO. | 'NO' |
| disable_damping | Bool | Damping is disabled for the linearization solver from all force elements for the eigenvalue solution when True. | False |
| write_energy_dist | Enum | The modal kinetic energy is written to the solver log file and the _linz.mrf output file when YES. One of YES, NO | 'NO' |
| trans_limit | Double | Defaults to 100 | |
| max_residual | Double | The upper limit for the change in residual of the system equations at the static equilibrium point. | 0.0001 |
| max_fi_tol | Double | The maximum force imbalance in the equations of motion that is allowed at the solution point. | 0.0001 |
| stability | Double | The fraction of the mass matrix that is to be added to the Jacobian to ensure that it is not singular. | 1e:10 |
| max_num_iter | Double | The maximum number of iterations that are allowed before simulation stops. Defaults to 75. * max_ke_tol (Double) : The maximum allowable residual kinetic energy of the system at the static equilibrium point. | 1e:5 |
| max_dq_tol | Double | The upper limit for the change in system states at the static equilibrium point | 0.001 |
| rot_limit | Double | Defaults to 1.04718. * h0_max (Double) : The maximum initial step size the integrator is allowed to take | 1e:8 |
| dae_minit | Double | The minimum number of iterations that the corrector is allowed to take before it checks for corrector divergence. | 0 |
| h_min | Double | The minimum initial step size the integrator is allowed to take. | 1e:6 |
| vel_tol_factor | Double | The factor that multiplies integr_tol to yield the error tolerance for velocity states. | 1000 |
| dae_maxit | Int | The maximum number of iterations that the corrector is allowed to take to achieve convergence. | 4 |
| dae_jacob_init | Int | Controls the Jacobian matrix evaluation during corrector iterations. | 0 |
| dae_index | Enum | The index of the DAE formulation. One of 1,3. | 3 |
| dae_alg_tol_factor | Double | The tolerance on all algebraic constraint equations that the corrector must satisfy at convergence. | 1000 |
| integrator_type | Enum | The integrator type. One of ABAM, VSTIFF, MSTIFF, DSTIFF. | DSTIFF |
| max_order | Int | The maximum order that the integrator is to take. | 5 |
| dae_eval_expiry | Double | Defaults to 0. * dae_interpolation (Bool) : | True |
| rel_abs_tol_ratio | Double | The relative to absolute tolerance ratio. | 0.01 |
| dae_constr_tol | Double | The DAE constraint tolerance. | 1e:5 |
| integr_tol | Double | The maximum absolute error per step that the integrator is allowed in computing the displacement, velocity, and differential equations states. | 0.01 |
| dae_vel_ctrl | Bool | The velocity states are checked for local integration error at each step when True. This option is only available in the case where the DAE index is 1. | False |
| dae_jacob_eval | Enum | The jacobian evaluation frequency. One of 0,1,2,3. | 0 |
| plot_responses | Bool | Defaults to True. * optimizer_log_level (Enum) : One of Normal,Debug or All. | 'Normal' |
| num_process | Double | Defaults to 1. * optimizer_method (Enum) : One of "SLSQP","NEWTON ","Nelder:Mead","Powell","CG","BFGS","Newton: CG","L:BFGS:B","TNC","COBYLA","dogleg","trust:ncg". Defaults to 'SLSQP'. * enable_optimizer (Bool) : | False |
| optimizer_dsatypes | Double | One of "AUTO","ADJOINT","DIRECT","Finite Differencing". | 'AUTO' |
| fdstep | Double | Finite differencing step size. | 1e:6 |
| accuracy | Double | Defaults to False. | 0.001 |
| opt_max_num_iter | Double | Max number of optimization iterations | 75 |
Examples
>>> # Import mview module
>>> from hw import mview
>>> # Get the model handle
>>> mod = mview.getModel()
>>> mod.name
'the_model'
>>> # Change the analysis type to static
>>> mod.simPara.analysis_type = 'STATIC'
'STATIC'
>>> # Change the minimum initial step size the integrator
>>> mod.simPara.h_min = 1e:5
>>> mod.simPara.h_min
1e:5Methods
- getValue(name)
Returns value of an attribute.
Parameters:
name (str) : Name of the attribute. Defaults to :.
Returns:
The return value. Return type depends on the attribute type.
- setValue(name, value)
- Sets value of an attribute.
Parameters:
name str Name of the attribute. value any Value of the attribute to be set. Returns:
Returns True if the value was successfully set else False.
Return type:
bool
