Torque Roll Axis
Plots the Torque Roll Axis with respected to the crankshaft axis direction.
View new features for NVH 2022.
Discover NVH functionality with interactive tutorials.
Set up the simulation model, materials, domains and boundaries.
Create, organize and manage the CAE parts.
Define radiation conditions and create emissivity models.
Calculate a response, perform contribution analysis, plot results, and perform diagnostic studies and study response changes.
Plot modal/panel participation curves from an OptiStruct .h3d file or an MSC Nastran .f06/.pch file.
The Grid Participation utility allows you to plot panel grid participation results and then use advanced scaling contour capabilities to isolate key contributing areas.
Visualize the distribution of energy within a full vehicle NVH model, as a way to understand what components are dominating the vehicle response.
Identifies the complex contribution of the excited structure through attachment points to a response in the responding structure.
Design sensitivity represents a change in response with respect to a change in a design variable, which is typically used for optimization.
Generates and post-processes engine order related data from an OptiStruct or Nastran frequency response analysis that contains either RPM-based loading subcases or order-based loading subcases.
Calculate a frequency response based on modal results.
The Model Correlation utility determines the degree of similarity or correlation between two sets of results.
The Equivalent Radiated Sound utility post-processes the results of exterior structure-borne radiated sound.
Identifies global modes from an OptiStruct or Nastran modal analysis.
The General Signal Processing utility processes the time domain pressure results from CFD simulations and visualizes the results in both the time and frequency domain.
Predicts powertrain rigid body mode frequencies and kinetic energy distribution, which play a critical role in optimizing the mount stiffness and layout configuration, by decoupling powertrain rigid body modes and reducing vibration transmission.
Enter the powertrain and mounting configuration data manually or load the data from a configuration file. Mount stiffness can be static or non-linear.
Review rigid body mode frequencies and corresponding kinetic energy distribution. Right-click on the context menu to display and visualize rigid body modes.
Plots mount displacements and reaction forces in various static, dynamic, and transient loading conditions, which aids in understanding the mount's load carrying capacity and the mount's interference with vehicle structure. Optionally, you can add custom static loadcases.
Perform sensitivity studies for mount position and stiffness. You can also perform an optimization setup to calculate the optimized mount stiffness and location layout for decoupling powertrain rigid body modes and frequency spacing.
Optimizes sensitive parameters for multiple sample analysis results using the RBDO approach.
Post-process results from a Multiple Sample Analysis, including plotting a spread of responses (+/-95% and mean).
Customize plots using the following options
Filters contributors to a smaller set of data.
ON THIS PAGE
ON THIS PAGE
