Figure 1. Create Parameters
Structural Output
Specifies the output reference quantity for structural subsystems. A reference value is required to normalize the output. For example, for global units of IPS, to get the structural response in g’s, select acceleration with a reference value of 386 (in/sec2).
Acoustic Output
Specifies the output reference quantity for acoustic subsystems. A reference value is required to normalize the output.
Energy Output
Specifies the output reference energy quantity for all subsystems. This value is not currently used in SEAM. Set the energy output reference quantity by editing the second entry on Line 12 of the SEAM parameter file.
Power Output
Specifies the output reference power quantity, including modal power, for all subsystems. This value is not currently used in SEAM. Set the power output reference quantity by editing the first entry on Line 12 of the SEAM parameter file.
Variance Options
Specifies the type of variance analysis, if any.
None
Omits the variance analysis.
Analysis Bandwidth
Uses the bandwidth specified in the Frequency Limits field for the variance analysis.
Narrowband
Performs a variance analysis.
Solution Type
Specifies if the analysis is steady-state or transient.
Select transient to activate the Transient Parameters section, where you can indicate:
  • If the system is to start at rest or at steady-state.
  • The total number of time steps.
  • The time steps per second.
SEAM has limited support for transient analysis, however more transient options are available under SEAM.
Output Options
Specifies if the output is in decibels or linear values.
SEAM Unit
Specifies the units the model is represented in.
Specifies options for the Transient Solution type.
Output Options
Specifies the format of the output quantities of responses.
Echo Print Input
Specifies the input files to echo in the output file.
Output Characteristics
Specifies the output quantities printed in the output file. If Response output is selected, you can output the response from all elements and subsystems or only selected subsystems by clicking and selecting one or more elements in the model. This is useful if the model has many elements and attention is focused on a smaller subset of elements.
Global Reference
Specifies the reference values required to normalize the output for different kinds of output.
