Plot
Click to plot responses from the analysis.
Use the Plot Manager to plot SEAM results. You can plot
model results versus a baseline model or overlay plots from different elements or
connections within the same model. The plot controls vary depending on the quantity
presented. Plot Manager has three sections:
- Results
- Results contains the list of responses available from solving the loaded model.
- Subsystems
- After selecting the result type, select a subsystem.
- Plot Section
- Used to display results of the analysis in a 2D plot.
