SEA Subsystem
- Import CAD geometry.
- Import an FE model.
- Use geometric entities.
In SEAM, a dynamic system is separated into a series of structural and acoustic elements. In the SEA analysis procedure, these elements are separated even further into SEA subsystems. A certain number of subsystems, or mode groups, are needed to completely describe the response of an element. However, in some cases, the loading and/or boundary conditions on a particular element justify the omission of certain standard subsystems and the addition of more complex subsystems in the analysis.
An SEA subsystem can be created using each specific option. Once a subsystem is created, you can assign properties and materials, which are created and assigned.
There are eight types of basic elements. Each icon in the SEAM ribbons corresponds to a different element type. These elements are categorized as structural and acoustic elements.
- Structural
- Plate
- Shell
- Beam
- Pipe
- Frame
- Acoustic
- Acoustic space (3D)
- Acoustic layer (2D)
- Acoustic duct (1D)
Create and Edit a Plate
A plate is a two-dimensional, flat panel structural element that supports bending and inplane deformation modes.
From the Model ribbon > SEA Subsystem group, click the Structural icon, followed
by the Plate tool.
Create a plate:
- Left-click in the modeling window to select a point or node until you are able to create a plate.
After selecting more than two points, a guidebar is displayed that you
can use to assign properties, , and damping, .
- Specify the plate name in the name field.
- Click and assign properties and damping, respectively.
Click Create to create a plate.
The required parameters to create the plate subsystem are updated.
Right-click on Plate to edit the subsystem and update
the parameters.
- Name
- Specify a unique name.
- ID
- Specify a unique ID.
- Config
- Specify the element type.
- Property
- Specify the property parameter based on the element type.
- Damping
- Specify damping to the subsystem.
- Geometry
- Based on the element type, update geometry parameters.
- Subsystem Options
- For experienced users, expand the Subsystem Options to change the default choices for the SEA Subsystems for all element types. For certain structural element types, use these options to adjust the default bending stiffness or conductance of the element and add non-structural mass, component mass, or fluid loading to the element when the options have been changed.
- Damping
- Assign a damping model to the element. From the Damping field drop-down menu, select a damping model. This list contains all predefined models which apply to the current element type. Click to display advanced damping options that you can use to define additional damping models.
- Properties
- Assign a property model to the element. From the Property field
drop-down menu, select a property model. The element materials and
cross-sectional parameters defined in the selected Property record
are displayed. Property records can be used to simplify the model
definition in cases where many elements have the same properties.
Click to display advanced property options
that you can use to define additional property models.
Create and Edit Space
Space is a three-dimensional, acoustic element supporting acoustic modes.
From the Model ribbon > SEA Subsystem group, click the Acoustic icon, followed
by Space tool.
Create space.
- Click a Surface, Plate, or Shell subsystem. If all subsystems or surfaces make it a closed entity, then it creates a cavity.
Once you select a proper closed entity, a guidebar is displayed that
you can use to assign properties, , and damping, .
- Specify the space name in the field.
Click Create to create space.
The required parameters to create a space subsystem are updated.
Right-click on space to edit the subsystem and update the parameters.
- Name
- Specify unique name.
- ID
- Specify unique ID.
- Config
- Property
- Damping
- Absorption 1
- Define or select the absorption entity and define the area about it.
- Geometry
- Subsystem Options
- Damping
- Properties
Create and Edit a Layer
A layer is a two-dimensional acoustic element that supports acoustic modes.
by the Layer tool.
Create a layer.
- Left-click in the modeling window to select a point or node until you are able to create a layer.
- Specify the name in the field.
Click Create to create a layer.
The required parameters to create the layer subsystem are updated.
Right-click on Layer to edit the subsystem and update
the parameters.
- Name
- ID
- Config
- Property
- Damping
- Absorption 1
- Geometry
- Subsystem Options
- Damping
- Properties
Create and Edit a Duct
A duct is a one-dimensional acoustic element that supports acoustic modes.
by the Duct tool.
Create a duct.
- Left-click in the modeling window to select a point or node until you are able to create a duct.
- Specify the duct name in the field.
Click Create to create a duct.
The required parameters to create the duct subsystem are updated.
Right-click on a Duct to edit the subsystem and update
the parameters.
- Name
- ID
- Config
- Property
- Damping
- Absorption 1
- Geometry
- Subsystem Options
- Damping
- Properties
Create and Edit a Shell
A shell is a two-dimensional flat panel structural element that supports bending and inplane deformation modes.
by the Shell tool.
Create a shell.
- Left-click in the modeling window to select a point or node until you are able to create a shell.
- Specify the name in the dialog.
Click Create to create a shell.
The required parameters to create the shell subsystem are updated.
Right-click on Shell to edit the subsystem and then
- Name
- ID
- Config
- Property
- Damping
- Geometry
- Subsystem Options
- Damping
- Properties
Create and Edit a Beam
A BEAM is a one-dimensional structural element with a constant cross-section that supports bending, torsional, longitudinal, and higher-order, cross-sectional deformation modes.
by the Beam tool.
Create a beam.
- Left-click in the modeling window to select a point or node until you are able to create a beam.
Click Create to create a beam.
The required parameters to create the beam subsystem are updated.
Right-click on beam to edit the subsystem and update the
parameters.
- Name
- ID
- Config
- Property
- Damping
- Geometry
- Subsystem Options
- Damping
- Properties
Create and Edit a Pipe
A pipe is a one-dimensional structural element with a constant cross-section that supports bending, torsional, longitudinal, and higher-order, cross-sectional deformation modes.
by the Pipe tool.
Create a pipe.
- Left-click in the modeling window to select a point or node until you are able to create a pipe.
Click Create to create a pipe.
The required parameters to create the pipe subsystem are updated.
Right-click on pipe to edit the subsystem and update the
parameters.
- Name
- ID
- Config
- Property
- Damping
- Geometry
- Subsystem Options
- Damping
- Properties
