Barlat's 3- parameter plasticity model is developed in F. Barlat, J. Lian
1 for modeling of sheet under plane stress assumption with
an anisotropic plasticity model. The anisotropic yield stress criterion for plane stress is
defined as:
(1)
Where,
and
are additional anisotropic material constants. All anisotropic
material constants, except for
which is obtained implicitly, are determined from Barlat width
to thickness strain ratio
(3)
Where,
is the uniaxial tension in the
direction. Let
= 45°,
式 4 gives an equation from which the
anisotropy parameter
can be computed implicitly by using an iterative
procedure:
(5)
注: Barlat's law reduces to Hill's law when using
=2
