Nonlinear finite element analyses confront users with many choices. An understanding of the fundamental concepts of
nonlinear finite element analysis is necessary if you do not want to use the finite element program as a black box.
The purpose of this manual is to describe the numerical methods included in Radioss.
Kinematic constraints are boundary conditions that are placed on nodal velocities. They are mutually exclusive for each degree
of freedom (DOF), and there can only be one constraint per DOF.
The stability of solution concerns the evolution of a process subjected to small perturbations. A process is considered
to be stable if small perturbations of initial data result in small changes in the solution. The theory of stability
can be applied to a variety of computational problems.
A large variety of materials is used in the structural components and must be modeled in stress analysis problems.
For any kind of these materials a range of constitutive laws is available to describe by a mathematical approach the
behavior of the material.
Explicit scheme is generally used for time integration in Radioss, in which velocities and displacements are obtained by direct integration of nodal accelerations.
The performance criterion in the computation was always an essential point in the architectural conception of Radioss. At first, the program has been largely optimized for the vectored super-calculators like CRAY. Then, a first parallel
version SMP made possible the exploration of shared memory on processors.
Hill's law models an anisotropic yield behavior. It can be considered as a
generalization of von Mises yield criteria for anisotropic yield behavior.
The yield surface defined by Hill can be written in a general form:(1)
Where, the coefficients , , , , and are the constants obtained by the material tests in different
orientations. The stress components 1j are expressed in the Cartesian reference parallel to the
three planes of anisotropy. 式 1 is equivalent to von Mises yield
criteria if the material is isotropic.
In a general case, the loading direction is not the orthotropic direction. In addition, we
are concerned with the plane stress assumption for shell structures. In planar anisotropy,
the anisotropy is characterized by different strengths in different directions in the plane
of the sheet. The plane stress assumption will enable to simplify 式 1, and write the expression of
equivalent stress as:(2)
The coefficients are determined using
Lankford's anisotropy parameter :(3)
Where, the Lankford's anisotropy parameters are determined by performing a simple tension test at angle
α to orthotropic
direction 1:(4)
The equivalent stress is compared to the yield stress which varies in function of plastic strain
and the strain rate (LAW32):(5)
Therefore, the elastic limit is obtained by:(6)
The yield stress variation is shown in 図 1. 図 1. Yield Stress Variation
The strain rates are defined at integration points. The maximum value is taken into
account:(7)
In Radioss, it is also possible to introduce the yield stress
variation by a user-defined function (LAW43). Then, several curves are defined to take into
account the strain rate effect.
It should be noted that as Hill's law is an orthotropic law, it must be used for elements
with orthotropy properties as TYPE9 and TYPE10 in Radioss.
Anistropic Hill Material Law with
MMC Fracture Model (LAW72)
This material law uses an anistropic Hill yield function along with an associated flow
rule. A simple isotropic hardening model is used coupled with a modified Mohr fracture
criteria. The yield condition is written as:
Where, is the Equivalent Hill stress given as:
For 3D model (Solid)
For Shell
Where, , , , , , and are six Hill anisotropic parameters.
For the yield surface a modified swift law is employed to describe the isotropic hardening
in the application of the plasticity models:
Where,
Initial yield stress
Initial equivalent plastic strain
Equivalent plastic strain
Material constant
Modified Mohr fracture criteria
A damage accumulation is computed as:
Where, is a plastic strain fracture for the modified Mohr
fracture criteria is given by:
Anisotropic 3D model
with:
Where,
Third invariant of the deviatoric stress
2D Anisotropic Model
With:
Where,
, and
Parameters for MMC fracture model
The fracture initiates when = 1.
In order to represent realistic process of an element, a softening function
is introduced to reduce the deformation resistance. The yield
surface is modified as:
with
Where,
Critical damage
We have crack propagation when in this case is considered to reduce the yield surface otherwise
the =1.
