RD-T: 3030 Buckling of a Tube Using Half Tube Mesh
This tutorial simulates buckling of a tube using half tube mesh with symmetric boundary conditions.
![rd3030_model](../../../images/solvers/rd3030_model.png)
図 1. Model
The model description is as follows:
- UNITS: Length (mm), Time (ms), Mass (kg), Force (kN) and Stress (GPa)
- Simulation time: Engine [0 - 10 ms]
- The tube thickness is 0.914 mm.
- An imposed velocity of 13.3 mm/ms (~30 MPH) is applied to the right end of the tube
- Elasto plastic material using Johnson-Cook law /MAT/PLAS_JOHNS (STEEL).
[Rho_Initial] Initial density = 7.85e-6 Kg/mm3
[E] Young's modulus = 210 GPa
[nu] Poisson coefficient = 0.3
[a] Yield Stress = 0.206 GPa
[b] Hardening Parameter = 0.450 GPa
[n] Hardening Exponent = 0.5
Model Files
必要なモデルファイルのダウンロードについては、モデルファイルへのアクセスを参照してください。
Input file for this tutorial: BOXTUBE_0000.rad
Start HyperCrash
- Open HyperCrash.
- Set the User profile to RadiossV2022 and the Unit system to kN mm ms.kg.
- Set User Interface style as New.
- Set your working directory to where the downloaded file is located.
- Click Run.
- Click .
- In the input window, select BOXTUBE_0000.rad.
- Click OK.
Create and Assign a Material
Create and Assign a Property
Define the Rigid Body
Define Boundary Conditions
Define Boundary Conditions Representing Symmetry
Define the Imposed Velocity
Define a Rigid Wall
Create a Self Contact for the Tube
Export the Model
Open Compute Console from the Windows Start Menu
![](../../../images/solvers/rd3030_solver_run_mgr.png)
図 17.
Review the Results
![](../../../images/solvers/rd3030_results_14.png)
図 18.
