PARAM, I64SLV
Bulk Data Entry Enforces the activation of internal long (64-bit) integer sparse direct solver.
| Parameter | Values | Description |
| I64SLV | <YES,
NO> Default = NO |
This parameter is used to
enforce the activation of internal long (64-bit) integer sparse
direct solver. With automatic memory allocation mode, the solver
automatically decides whether or not to switch the 64-bit integer
solver on. However, even if the 64-bit integer solver is not the
preferred choice in certain scenarios, this parameter can still be
used to enforce activation.
