PARAM, NLRFILE
Bulk Data Entry This parameter controls the output of restart files (R-File) in geometric nonlinear analysis.
Note: Obsolete parameter - use RADPRM, NLRFILE.
Parameter Values Description
NLRFILE <YES, NO> This parameter controls the output of restart files (R-File) in geometric nonlinear analysis.
YES
The restart files are retained after geometric nonlinear analysis.
NO (Default)
The restart files are removed after geometric nonlinear analysis.
