I/O Options Defaults Summary
Output Format Controls
Card When card is not present When card is present, but no argument is given
OUTPUT no effect no effect
*The OptiStruct Configuration File may be used to change the default settings.
Run Controls
CHECK No effect Active (has no arguments)
CMSMETH No effect No effect
NLRESTART No effect Restarts from the first NL subcase that errored out in the previous run.
RESTART No effect <prefix of filename>.sh
SYSSETTING No effect No effect
@ HyperForm No effect Active (has no arguments)
File Names, Headers, and Locations
ASSIGN N/A Error
EIGVNAME OUTFILE is used Error
INCLUDE N/A Error
LOADLIB N/A Error
OUTFILE Prefix of filename Error
SUBTITLE N/A Blank
TITLE N/A Blank
TMPDIR ./ or .\ Error
Analysis Output
ACCELERATION NONE ALL
AUTOSPC NO YES
CFAILURE NONE ALL/YES
CONTF NONE ALL
CSTRAIN NONE ALL
CSTRESS NONE ALL
DAMAGE NONE ALL
DISPLACEMENT ALL 2 ALL
EDE NONE ALL
EKE NONE ALL
ELFORCE See FORCE
ELSTRESS See STRESS
ENDLOAD NONE ALL
ENERGY NONE ALL
ERP NONE ALL
ESE NONE ALL
FLUX NONE ALL
FORCE NONE ALL
GPFORCE NONE ALL
GPKE NONE ALL
GPSTRESS NONE ALL
GSTRESS See GPSTRESS
LIFE NONE ALL
MBFORCE no effect ALL
MECHCHECK no effect N/A
MODALDE NONE ALL
MODALKE NONE ALL
MODALSE NONE ALL
MPCFORCE NONE ALL
NLLOAD NONE ALL
OLOAD NONE ALL
PFGRID NONE error
PFMODE NONE error
PFPANEL NONE error
PFPATH NONE error
POWERFLOW NONE ALL
PRESSURE ALL † ALL
PRETBOLT NO YES
REQUEST NONE Error (has no arguments)
SACCELERATION NONE ALL
SDISPLACEMENT NONE ALL
SINTENS NONE ALL
SPCFORCE NONE ALL
SPL NONE ALL
SPOWER NONE ALL
STRAIN NONE ALL
STRESS ALL 1 ALL
SVELOCITY NONE ALL
TCURVE N/A Blank
THERMAL NONE ALL
THIN NONE ALL
UNITS NONE Error (has no arguments)
VELOCITY NONE ALL
XTITLE N/A Blank
XYPEAK NONE Error
XYPLOT NONE Error
XYPUNCH NONE Error
YTITLE N/A Blank
Other Output Controllers
DMIGNAME AX AX
ECHO No effect Active
ECHOON No effect Active (has no arguments)
ECHOOFF No effect Active (has no arguments)
MODEL ALL ALL
MSGLMT No effect Error
OFREQUENCY ALL ALL
OMODES ALL ALL
OTIME ALL ALL
SCREEN NONE OUT
TTERM NONE REAL
Random Response
RCROSS None Error
Optimization
DGLOBAL None Error
FE Analysis
HYBDAMP None Error
RADSND No effect Error
Miscellaneous
DEBUG For HW support use only For HW support use only
1 Except for frequency response and transient subcases, where the default is NONE.
2 Except for frequency response subcases, where the default is NONE.
