ENERGY
I/O Options and Subcase Information Entry Used to request energy output for all geometric nonlinear analysis subcases or individual geometric nonlinear analysis subcases, respectively.
ENERGY (format, type) = option
Argument | Options | Description |
format | <H3D, blank> |
type | <ALL, ENERG, HOURG> |
option | <YES, ALL, NO,
NONE, SID,
PSID> Default = ALL |
- ENERGY is only applicable for Geometric Nonlinear Analysis Subcases which are defined by an ANALYSIS= EXPDYN Subcase Information Entry. It is ignored for all other subcases.
- Only formats that have been activated by an OUTPUT statement are valid for use on this card.
- Multiple formats are allowed on the same entry; these should be comma separated. If a format is not specified, this output control applies to all formats defined by the OUTPUT command, for which the result is available.
- Multiple instances of this card are allowed. If instances are conflicting, the last instance dominates.
