MDSDIR
I/O Options EntryUsed to choose the location of the Altair Multiscale Designer™ installation.
MDSDIR=path
MDSDIR = “C:\Program Files\Altair\2021\hwsolvers\MultiscaleDesigner"
| Argument | Options | Description |
| path | <directory
                                        path> Default: See Comment 1  |
                                Path to the location of the Multiscale Designer installation. |
- OptiStruct will automatically use the Multiscale Designer installation within the same Mechanical Solvers installation from which OptiStruct is being run. If you want to use a different Multiscale Designer installation, then the MDSDIR entry can be used.
 - The MATMDS Bulk Data Entry references the ASSIGN entries, which point to the corresponding material model data files from Multiscale Designer.
 - MDSDIR can also be defined in the OptiStruct Configuration File.
