NOUTPUT
I/O Options EntryUsed to specify the segments for which results must be recovered and output, in cyclic symmetry analysis.
NOUTPUT = option
NOUTPUT = 65
SET 65 = 1,3,4,8
Argument | Options | Description |
option | <ALL, SETID> No default |
(Integer > 0) |
- NOUTPUT is required in cyclic symmetry analysis.
- The segment identification numbers on the SET entry should be positive and not exceed the total number of segments (NSEG in CYSYM Bulk Data Entry).
- Results from the basic segment (segment 1) is always output irrespective the segments mentioned in the set, when option = SETID is used.
- For more information on segment numbering, refer to CYSYM.
- Currently, the output is only available in .h3d format.
