SINTENS
I/O Options and Subcase Information Entry The SINTENS command can be used in the I/O Options section to request Sound Intensity output for all frequency response subcases. The SINTENS command can be used in the I/O Options or Subcase Information sections to request Sound Intensity output for all subcases or individual subcases, respectively.
SINTENS(type) = option
Argument Options Description
type <PANEL, NOPANEL>
Default = PANEL
PANEL, blank
Sound Intensity is output for both panels and microphone locations.
NOPANEL
Sound Intensity is output only for microphone locations.
option <ALL>
Default = ALL
ALL, blank
Sound Intensity is output for all panel grids and all grids defined as microphone locations on the RADSND Bulk Data Entry. In addition, the total Sound Intensity for each panel and all the microphone locations is output.
Note: Sound Intensity is output only for microphone locations, if type=NOPANEL is specified.
  1. When the SINTENS command is present, Sound Intensity is output for all RADSND panel grids and all microphone grids for all frequency response subcases.
  2. Sound Intensity results (via SINTENS) are output to the .h3d file.
  3. SINTENS can only be requested for frequency response subcases.
  4. Sound intensity is always output for microphone locations regardless of the specified type (PANEL/NOPANEL).
