FORMAT
I/O Options EntryThe FORMAT command can be used in the I/O Options section to indicate the format in which results are to be output.
FORMAT = option
Argument | Options | Description |
option | <ASCII, OS, OPTI, HM, HYPER, BOTH, H3D, FLX, NASTRAN, PUNCH, PATRAN, APATRAN, O2, OUT2, OUTPUT2, PLOT,HDF5, KPI, NONE> |
- Information provided on OUTPUT entries take precedence over information provided on FORMAT entries. If neither of these entries are defined, the output formats defined in the Configuration File are used. If a format is not defined by the Configuration File, then both the HM and H3D formats are active by default.
- Multiple FORMAT commands are allowed.
- It is recommended to use the OUTPUT command instead of the FORMAT command since it is more flexible and allows different frequencies of output for different formats during an optimization.
- The HDF5 output is printed to a
.h5 binary results file. For details of the supported
analysis types and elements when the .h5 output format is
requested, refer to the .h5 file.
For details about the old HDF5 format (.hdf5), refer to PARAM, HDF5 and .hdf5 file.
- KPI output includes maximum value for Displacement, Stress, Strain, and Plastic Strain with respect to the corresponding property. It is supported for linear and nonlinear static analysis only. Stresses and Strains are supported only for shells and solids. This output can also be activated from the corresponding I/O Options Entry (DISPLACEMENT, etc).
