RD-E: 0600 Fuel Tank
The fluid-structure interaction and the fluid flow are studied in cases of a fuel tank sloshing and overturning. A bi-phase liquid-gas material with an ALE formulation is used to define the interaction between water and air in the fuel tank.
![rad_ex_6_fueltank](../../../images/solvers/rad_ex_6_fueltank_zoom89.png)
In the case of sloshing, the fuel tank is subjected to a horizontal deceleration. The fuel tank container is modeled with a Lagrangian formulation and undergoes an elasto-plastic material law. Fluid structure coupling is taken into account.
The overturning of the fuel tank is studied by applying a variable deceleration. The tank container is not modeled as the boundary nodes are fixed. The Eulerian formulation is used.
