/INTER/TYPE12
Block Format Keyword Interface TYPE12 described fluid to fluid contact and enables the transmission of flow between two ALE surfaces (main and secondary side). The secondary node velocities are interpolated from main surface values. Then convective fluxes are calculated between the two surfaces.
The surfaces can be defined from moving grids: in this case, associations between secondary nodes and main segment are updated during calculation. 1 234 5
inter_type12
/INTER/TYPE12/inter_ID
inter_title
surf_IDs surf_IDm   Interpol
        Tol
ITIED Bcopt skew_ID node_ID
If ITIED =2, Transformation parameters for periodic connection 8
XC YC ZC
XN YN ZN θ
XT YT ZT
inter_ID Interface identifier.
(Integer, maximum 10 digits)
inter_title Interface title.
surf_IDs Secondary surface identifier. 1
(Integer)
surf_IDm Main surface identifier. 1
(Integer)
Interpol Interpolation flag. 5
= 0
Linear.
= 1
Polar.
(Integer)
Tol Tolerance for segment search.
Default = 0.02 (Real)
[ m ]
ITIED Option for surface connection. 4
= 0
Free.
= 1
Tied.
= 2
Periodic.
= 3
No convection.
(Integer)
Bcopt Kinematic constraint deactivation flag. 6
= 0
Default.
= 1
All nodes considered.
= 2
Secondary nodes will be omitted.
= 3
Secondary nodes and fully fixed nodes will be omitted.
(Integer)
skew_ID Skew system identifier for polar interpolation. 5
(Integer)
node_ID Reference node number for polar interpolation. 5
(Integer)
XC X coordinate of center of rotation.
(Real)
[ m ]
YC Y coordinate of center of rotation.
(Real)
[ m ]
ZC Z coordinate of center of rotation.
(Real)
[ m ]
XN X component of the vector defining the rotation axis.
(Real)
[ m ]
YN Y component of the vector defining the rotation axis.
(Real)
[ m ]
ZN Z component of the vector defining the rotation axis.
(Real)
[ m ]
θ Angle of rotation.
(Real)
θ
XT X component of translation vector.
(Real)
[ rad ]
YT Y component of translation vector.
(Real)
[ m ]
ZT Z component of translation vector.
(Real)
[ m ]
  1. Main surface must be coarser or equal to secondary surface. Each main segment needs at least on secondary node on the opposite surface.
  2. You may act on grid velocities with ALE boundary conditions (/ALE/BCS), ALE links (/VEL/ALE (Obsolete)), or with a porous property (/PROP/TYPE15 (POROUS)) which enable to apply a rigid body motion.
  3. This interface, like interface TYPE2, is a kinematic condition. No other kinematic condition should be set on any node of the secondary surface.
  4. ITIED flag sets the connection formulation.
    • If ITIED = 0 (free)
      The algorithm continuously searches for a main segment neighbor corresponding to each secondary node. The node does not need to lie in the segment plane. This is the general case.
      ITIED_0
    • If ITIED = 1 (tied)
      The neighbor search is performed initially and the grid velocity is then computed to keep the secondary node on its initial main segment.
      ITIED_1
      Figure 3.
    • If ITIED = 2 (periodic)
      A transformation matrix (translation and rotation defined from lines 6 to 8) is applied to the secondary nodes. Neighbors are then searched as for option ITIED =1. This allows communication between two faces of one or two different domains to reproduce angular periodicity: all material exiting from one side is injected on the other side after rotation.
      ITIED_2
      Figure 4.
    • If ITIED = 3 (no convection)
      Only the momentum equation couples the two surfaces and convection of density, energy are inhibited. This can be used to couple one Lagrangian side and a fluid side with meshes remaining independent. The result is normally a one-way coupling. Setting explicitly the modification scale factor fluxes to 1 in the relevant /ALE/MAT will activate two-way coupling.
    Except for formulation ITIED = 1 you have to check that the interface nodes are facing the corresponding surface.
  5. For rotating machines, polar interpolation in perpendicular directions is more accurate.
    • If Interpol = 1, you should provide a skew (skew_ID) for rotation axis and a center (node_ID); otherwise the following defaults are used.
    • If skew_ID =0, the global x-axis is the polar axis. If a center node is provided (node_ID), it will be treated as the origin of the polar coordinate system, otherwise global origin is used.
    • If a skew system is provided, the first axis of the skew is the polar axis. If the skew system type is "moving", the first node given in the skew system is considered; otherwise if defined the center node (node_ID) is the origin, if not defined the global origin (0,0,0) is used.
  6. This Bcopt option allows delete secondary nodes in the interface treatment of momentum. The nodes are deleted if other kinematic conditions are applied, depending on the flag value.
    • Bcopt = 0: Default value set to 2
    • Bcopt = 1: No node deleted. Warnings are displayed for nodes, to which other kinematic conditions have been set. This is not recommended, but allowed, as long as the several kinematic conditions result in the same behavior (for example, a secondary node may have fixed b.c.) when it is tied to a fixed main node.
    • Bcopt = 2: Secondary nodes will be omitted if they are also secondary of a Lagrange/Lagrange interface (/INTER/LAGMUL/TYPE2) or secondary of a rigid body. Other conflicting kinematic conditions will issue a warning as in option 1.
    • Bcopt = 3: Same as option 2; but fully fixed nodes are also omitted.
    This option does not affect mass and energy transfer.
  7. Transformation matrix results from a rotation of angle θ around axis (XN, YN, and ZN) with center (XC, YC, and ZC), followed by a translation (XT, YT, and ZT).
  8. This interface is not compatible with ALE multi-material LAW37 and LAW51.
