/INTER/TYPE9
Block Format Keyword Describes the ALE Lagrange with void opening and free space. Non-impacted ALE nodes are on a free surface. The grid velocity is equal to the material velocity in normal direction. The normal of the main surface elements must be oriented toward the secondary nodes.
/INTER/TYPE9/inter_ID
inter_title
surf_IDA surf_IDL
RTH Fric Gap
  ITH IEUL   Upwind FS
inter_ID Interface identifier.
(Integer, maximum 10 digits)
inter_title Interface title.
surf_IDA ALE secondary surface identifier.
(Integer)
surf_IDL Lagrangian main surface identifier.
= 0
This interface is used as ALE free surface.
(Integer)
RTH Thermal resistance per surface unit.
(Real)
[ K W ]
Fric Coulomb friction.
(Real)
Gap Gap for impact activation.
(Real)
[ m ]
ITH Thermal bridge flag.
= 1
Yes.
(Integer)
IEUL Eulerian behavior in tangent direction flag.
= 1
The grid velocity is set to zero in the tangent direction of the surface for non-impacted secondary nodes. The grid velocity of impacted nodes is fixed by the main segment. Flag IEUL is ignored for secondary nodes having a grid boundary condition.
(Integer)
Upwind Upwind for free surface normal computation.
= 0
No upwind.
= 1
Full upwind.
(Real)
FS Surface tension force.
(Real)
[ N ]
  1. Format Line 5 is not compatible with the main/secondary formulation of rigid bodies. If some nodes of the Lagrangian main surface are in a rigid body, the rigid body motion does not take into account the interfaces forces applied to these nodes.
