/NODE
Block Format Keyword Defines the coordinate of node, which is fundamental unit of graphic in structure.
/NODE/unit_ID
node_ID Xc Yc Zc
unit_ID Unit Identifier.
(Integer, maximum 10 digits)
node_ID Node identifier.
(Integer)
Xc X coordinate.
(Real)
Yc Y coordinate.
(Real)
Zc Z coordinate.
(Real)
  1. Nodes may be defined with more than one block.
