/PROP/TYPE3 (BEAM)
Block Format Keyword Describes the beam property for torsion, bending, membrane or axial deformation.
| /PROP/TYPE3/prop_ID/unit_ID or /PROP/BEAM/prop_ID/unit_ID | |||||||||
| prop_title | |||||||||
| Ismstr | |||||||||
| dm | df | ||||||||
| Area | IYY | IZZ | IXX | ||||||
| Ishear | |||||||||
| prop_ID | Property identifier (Integer, maximum 10 digits) |
| unit_ID | Unit Identifier (Integer, maximum 10 digits) |
| prop_title | Property title (Character, maximum 100 characters) |
| Ismstr | Small strain option flag.
(Integer) |
| dm | Beam
membrane damping Default = 0.00 (Real) |
| df | Beam
flexural damping Default = 0.01 (Real) |
| Area | Cross section (Real) |
| IYY | Area
moment of inertia, bending. (Real) |
| IZZ | Area
| IXX | Area
moment of inertia, torsion. (Real) |
| Rotation DOF code of nodes 1 and 2 (see detail input below). (6 Booleans) |
| Ishear | Beam
formulation flag.
(Integer) |
Detail of Rotation DOF Input Fields for Nodes 1 and 2
| (1)-1 | (1)-2 | (1)-3 | (1)-4 | (1)-5 | (1)-6 | (1)-7 | (1)-8 | (1)-9 | (1)-10 |
| = 1
Rotation DOF about X at node 1 is released. (Boolean) |
| = 1
Rotation DOF about Y at node 1 is released. (Boolean) |
| = 1
Rotation DOF about Z at node 1 is released. (Boolean) |
| = 1
Rotation DOF about X at node 2 is released. (Boolean) |
| = 1
Rotation DOF about Y at node 2 is released. (Boolean) |
| = 1
Rotation DOF about Z at node 2 is released. (Boolean) |
Example (Beam)
#RADIOSS STARTER
/UNIT/2
unit for prop
g mm ms
/PROP/BEAM/4/2
beam (bXh=10X10)
# Ismstr
0
# dm df
0 0
# Area Iyy Izz Ixx
100 833.33 833.33 1666.66
# Rot Ishear
000 000 0
#ENDDATA
#---1----|----2----|----3----|----4----|----5----|----6----|----7----|----8----|----9----|---10----|Comments
- Small strain formulation is activated from time t=0, if Ismstr =1. It may be used for a faster preliminary analysis because is constant, but the accuracy of results is not ensured.
- The strains and
stresses which are given in material laws are engineering strains
and stresses. Time history output returns engineering strains and
stresses.
