/QUAD
Block Format Keyword Describes the 2D solid elements. QUAD elements must be defined in the global YZ plane.
| /QUAD/part_ID | |||||||||
| quad_ID | node_ID1 | node_ID2 | node_ID3 | node_ID4 | |||||
| Field | Contents | SI Unit Examples |
| part_ID | Part identifier of the
block. (Integer, maximum 10 digits) |
| quad_ID | Element
identifier. (Integer) |
| node_ID1 | Node identifier
1. (Integer) |
| node_ID2 | Node identifier
2. (Integer) |
| node_ID3 | Node identifier
3. (Integer) |
| node_ID4 | Node identifier
4. (Integer) |
- The identifier must be unique in each element family, but it is advised for each element type to have a unique element identifier in the global model.
- More than one quad block can be used to define a part.
- Any number of quads can be defined in one block.
- The QUAD elements must be defined in the
global YZ plane with the element normal pointing in global X direction.
