/RANDOM
Block Format Keyword Describes the nodal random noise to check stability of model by introducing random noise on nodal coordinates.
/RANDOM/unit_ID or | |||||||||
/RANDOM/GRNOD/grnd_ID/unit_ID | |||||||||
Xalea | Seed |
grnd_ID | Node
group identifier (defined only if the keyword
GRNOD is
set). (Integer) |
unit_ID | Unit Identifier. (Integer, maximum 10 digits) |
Xalea | Maximum nodal random
noise. Range: [0, + ∞] (Real) |
Seed | Seed of random
noise. Range: [0, 1] (Real) |
- Xalea is the maximum magnitude of generic random noise applied to specified nodes coordinates (any direction). The modified coordinate = original one + Xalea * random number defined by Radioss (random number is defined between 0 and 1).
- Seed is a Real corresponding to the value used to initialize random number generation that should be set between 0 and 1 (1 excluded) for sensitivity analysis or model robustness investigation purpose.
- If the Ipri flag defined in /IOFLAG option has a value greater than or equal to 4, the output log file will contain a listing of new node coordinates.
- Two computations with the same values for Xalea and Seed will lead exactly to the same results.
- If a plain /RANDOM option is used (without GRNOD keyword), the random noise is applied to all nodes. When present, it should be defined only once and be the only random noise option.
- The /RANDOM/GRNOD definition is optional and allows to specify a node group affected by random noise. Multiple random noise groups may be defined; however, if one or more /RANDOM/GRNOD blocks are present, the random noise is applied only to the specified node groups, regardless if a plain /RANDOM option is present or not.
- Several definitions with groups containing common nodes are allowed, but the randomization of coordinates will be applied more than once for these nodes.
- For more information on how to define random noise with a command, refer to Starter Command Line Arguments.
