Isotropic, kinematic or uncoupled spring hardening options can be defined by the
hardening flag
H
MathType@MTEF@5@5@+=
feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn
hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr
4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9
vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9
Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaaciGGNbaaaa@374B@
Nonlinear Elastic Spring, H=0
A nonlinear elastic spring is modeled by defining a force versus displacement curve
where
f
1
feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbwvMCKf
MBHbqefqvATv2CG4uz3bIuV1wyUbqedmvETj2BSbqefm0B1jxALjhi
ov2DaebbnrfifHhDYfgasaacH8srps0lbbf9q8WrFfeuY=Hhbbf9v8
qqaqFr0xc9pk0xbba9q8WqFfea0=yr0RYxir=Jbba9q8aq0=yq=He9
q8qqQ8frFve9Fve9Ff0dmeaacaGacmGadaWaaiqacaabaiaafaaake
aaciGGMbWaaSbaaSqaaiaaigdaaeqaaaaa@3AAA@
in
Figure 2 is defined in
fct_ID 1i . Since the model
is elastic, the loading and unloading follow the same path.
Figure 2. Nonlinear elastic spring. with
H
=0
Nonlinear Elastic Plastic Spring with Isotropic Hardening, H=1
Figure 3 shows the behavior of a nonlinear elastic plastic spring with
isotropic hardening where
f
1
is defined in
fct_ID 1i and unloading
stiffness
K
u
aacaWGlbWaaSbaaSqaaiaadMgaaeqaaaaa@3AC1@
is input using
K
i
Figure 3. Isotropic hardening. with
H
=1
To demonstrate istropic hardening,
H
=1,
Figure 4 shows a spring loaded in tension and then
unloads using the linear unloading stiffness,
K
u
aacaWGlbWaaSbaaSqaaiaadwhaaeqaaaaa@3ACD@
. The unloading stiffness continues to be used in
compressive loading until the loading force in compression matches the maximum
loading force in tension. From this point, any additional compressive loading uses
the input loading function.
Figure 4. Cyclic loading applied on a spring. with
H
=1
Nonlinear Elastic Plastic Spring with Uncoupled Hardening, H=2
The force versus displacement curve
f
1
in
Figure 5 is defined in
stiffness
K
u
is input using
K
i
. When uncoupled harding
H
=2, is used, the tensile and compression behavior are
uncoupled. Thus, once the unloading reaches zero force, there is no stiffness until
zero displacement and then the compressive loading follows the force displacement
curve.
Figure 5. Isotropic hardening. with
H
=2
Nonlinear Elastic Plastic Spring with Kinematic Hardening, H=4
When
H
=4 is used, the loading function
fct_ID 3i are mandatory and
shown in
Figure 6 as
f
1
and
f
3
aaciGGMbWaaSbaaSqaaiaaiodaaeqaaaaa@3AAC@
. The loading curve should be positive for all values
of abscissa. The unloading curve in this case should be negative for all values of
abscissa. These curves represents upper and lower limits of yield force as function
of current spring length variation or strain. The force follows
K
between function
f
1
and
f
3
and is input as
K
i
Figure 6. Kinematic Hardening. with
H
=4
Figure 7. Cyclic loading applied on a spring. with kinematic hardening
H
=4
If the minimum and maximum yield curves (
f
1
and
f
3
) have identical shapes, the hardening is considered
to be kinematic.
Figure 8.
H
=4, with the minimum and maximum yield
curves. (
f
1
and
f
3
) input with identical shapes
Nonlinear Elastic Plastic Spring Nonlinear Unloading, H=5
When
H
=5, uncoupled hardening in compression and tensile
with nonlinear unloading is modeled.
Function
f
3
defines the residual displacement
δ
r
e
s
i
d
Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaacqaH0oazda
WgaaWcbaGaamOCaiaadwgacaWGZbGaamyAaiaadsgaaeqaaaaa@3CDF@
related to displacement; where the unloading starts
at
δ
p
e
a
k
WgaaWcbaGaamiCaiaadwgacaWGHbGaam4Aaaqabaaaaa@3BE4@
. The unloading is defined by:
(1)
F
K
f
3
α
δ
δ
r
e
s
i
d
n
Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaaciGGgbWaae
WaaeaacaWGlbGaaiilaiGacAgadaWgaaWcbaGaaG4maaqabaaakiaa
wIcacaGLPaaacqGH9aqpcqaHXoqydaqadaqaaiabes7aKjabgkHiTi
abes7aKnaaBaaaleaacaWGYbGaamyzaiaadohacaWGPbGaamizaaqa
baaakiaawIcacaGLPaaadaahaaWcbeqaaiaad6gaaaaaaa@4A7D@
with,
δ
r
e
s
i
d
f
3
δ
p
e
a
k
WgaaWcbaGaamOCaiaadwgacaWGZbGaamyAaiaadsgaaeqaaOGaeyyp
a0JaciOzamaaBaaaleaacaaIZaaabeaakmaabmaabaGaeqiTdq2aaS
baaSqaaiaadchacaWGLbGaamyyaiaadUgaaeqaaaGccaGLOaGaayzk
aaaaaa@46E7@
Where,
α and
n
being computed using
K
Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaacaWGlbaaaa@372E@
and
f
3
δ
p
e
a
k
Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaaciGGMbWaaS
baaSqaaiaaiodaaeqaaOWaaeWaaeaacqaH0oazdaWgaaWcbaGaamiC
aiaadwgacaWGHbGaam4AaaqabaaakiaawIcacaGLPaaaaaa@3F56@
. The loading function
f
1
in
Figure 9 is defined in
fct_ID 1i and residual
deformation function
f
3
input as
fct_ID 3i .
Figure 9. Nonlinear unloading. with
H
=5
In
Figure 10 , a linear curve is defined for
δ
r
e
s
i
d
and
δ
p
e
a
k
in function
f
3
δ
r
e
s
i
d
is 0.5 times
δ
p
e
a
k
. In cycle loading, the first unloading started at
δ
p
e
a
k
1
0.05
WgaaWcbaGaamiCaiaadwgacaWGHbGaam4AaiaaigdaaeqaaOGaeyyp
a0JaaGimaiaac6cacaaIWaGaaGynaaaa@4094@
and then
δ
r
e
s
i
d
0.5
0.05
0.025
a0JaaGimaiaac6cacaaI1aGaey41aqRaaGimaiaac6cacaaIWaGaaG
ynaiabg2da9iaaicdacaGGUaGaaGimaiaaikdacaaI1aaaaa@49BD@
. The second unloading started at
δ
p
e
a
k
2
0.1
WgaaWcbaGaamiCaiaadwgacaWGHbGaam4AaiaaikdaaeqaaOGaeyyp
a0JaaGimaiaac6cacaaIXaaaaa@3FD7@
and then
δ
r
e
s
i
d
0.5
0.1
0.05
a0JaaGimaiaac6cacaaI1aGaey41aqRaaGimaiaac6cacaaIXaGaey
ypa0JaaGimaiaac6cacaaIWaGaaGynaaaa@4843@
Figure 10. Linear residual versus maximum displacement curve. with
H
=5
Figure 11 shows how increasing the slope of the
residual versus maximum displacement curve changes the spring behavior.
Figure 11. Different linear residual versus maximum displacement
curves. with
H
=5
Comparing Figure 10 and Figure 11 , shows that the function
f
3
only effects the residual displacement
δ
r
e
s
i
d
and the shape of unloading curve. The shape of
unloading curve is controlled by stiffness
K
and
δ
p
e
a
k
(unloading start displacement).
If the same stiffness
K
and same
δ
p e a k
are used, then the unloading curve
has the same shape.
K
but different
δ
p
e
a
k
are used, then the unloading curve has a different
shape.
If a different stiffness
K
and same
δ
p
e
a
k
shape, as shown in
Figure 12 .
Figure 12. Different
K
values. with
H
=5
Nonlinear Elastic Plastic Spring Istropic Hardening and Nonlinear Unloading, H=6
Both
H
=1 and
H
=6 represent isotropic hardening. In
H
=6, a nonlinear unloading with function
f
3
is used while
H
=1 uses a constant
K
u
for linear unloading. When the spring is loaded in
tension and then unloads, it follows the defined unloading curve. The unloading
curve continues to be used in compressive loading until the loading force in
compression matches the maximum loading force in tension. From this point,
additional compressive loading uses the input loading function. The loading curve in
f
1
is defined using
curve in
f
3
is defined using
fct_ID 3i .
Figure 13. Istropic hardening and nonlinear unloading. with
H
=6
Nonlinear Elastic Plastic Spring Elastic Hysteresis, H=7
With
H
=7, the spring unloading is initially linear using
the input
K
value until it reach the unloading curve
f
3
. Additional unloading follows
f
3
. If reloading occurs, the stiffness
K
is used to reach the curve
f
1
, which is then followed. The curve
f
3
must have ordinates smaller than curve
f
1
at a defined abscissa value. The loading curve in
f
1
is defined using
curve in
f
3
is defined using
fct_ID 3i .
Figure 14. Nonlinear elastic plastic spring elastic hysteresis. with
H
=7
A spring with
H
=7 could be used to describe hysteresis behavior.
Figure 15 shows the difference between
H
=0 and
H
=7 under cycle loading. With
H
=0 (blue curve), it is nonlinear elastic. But with
H
=7 (red curve), more energy (yellow area in first
loop) is absorbed, due to the hysteresis loop.
Figure 15. Comparison of nonlinear elastic with hysteresis
H
=7. and Nonlinear Elastic
H
=0
Nonlinear Elastic Total Length Function, H=8
The elastic total length spring
H
=8 is only available in
/PROP/TYPE4 . Unlike the other hardening options which use the
change in spring length, this spring uses the total spring length when defining the
spring stiffness. No stiffness occurs in compression. Input
fct_ID 1i to define the force
versus total spring length.
Figure 16. Nonlinear elastic total length function. with
H
=8
Figure 17. Comparison of
H
=0 . and
H
=8 with Cyclic Loading Applied
