Mirror
Mirror parts across a symmetry plane.
- To link the mirrored part to the original, select Instance in the Find Options . Whenever one part is updated, the other will be automatically updated as well.
- To reposition the mirror plane using the Move tool, click .
- To align the mirrored object to the x-, y-, or z-axis, click .
- To merge two coincident faces, box select the faces before opening the Mirror tool. This technique works well with mirrored parts.
Keyboard Shortcuts & Mouse Controls
To | Do this |
Add to or remove from the selection | Ctrl |
Exit tool | Right-click and mouse through the check mark to exit, or double-right-click. |
