Scale
Resize parts in your model, which is useful when working with an imported model that is associated with a different default unit system.
Apply a Variable to a Parameter
Apply a variable to a parameter, or create a new variable on the fly from a tool microdialog.
You can apply existing variables and add new ones via the microdialog in various sketch and geometry tools.
- You can also create a variable by entering a new name and expression in the
microdialog’s text field, for example:
Variable1=50
- In addition, you can also create a new variable based on an existing
variable, for example,
Variable2=Variable1*0.5
Keyboard Shortcuts & Mouse Controls
To | Do this |
Add to or remove from the selection | Ctrl |
Select a point on a face as the scaling center | Shift |
Exit tool | Right-click and mouse through the check mark to exit, or double-right-click. |
