Wrap
Use the Wrap tool to quickly wrap a PolyNURBS solid around an optimized shape. You can create multiple PolyNURBS cages, and bridge the face of one cage to another. You can also wrap a hole or negative space.
- You can start or end a block from any existing cage face. You can also end a block on a planar face.
- Rotate an existing cage face using the graphic manipulators that appear when you mouse over an edge.
Wrap Holes
Use the Wrap Holes tool to wrap a hole or negative space in a polyNURBS or optimized shape.
Keyboard Shortcuts & Mouse Controls
To | Do this | Notes |
Change the section preview so that it is aligned to the underlying shape rather than parallel to the face |
Alt | |
Change the transparency of the underlying shape (STL or optimization result) | Alt+middle mouse scroll | |
Create an edge loop when selecting an edge | Shift | |
Exit tool | Right-click and mouse through the check mark to exit, or double-right-click. |
