Split
Use the Split tools to split a cage with a loop or split a single PolyNURBS cage face.
Split Cage with Loop
Draw an edge loop around a cage, subdividing the PolyNURBS object to gain more control when editing the cage.
  1. On the PolyNURBS ribbon, select the Split Cage with Loop tool.
  2. Click the edge of an existing cage to create a loop perpendicular to that edge. Mouse over an existing edge to preview the loop.
    The loop is created at the point where you clicked.
  3. Optional: To reposition the loop:
    • Drag the loop.
    • Hold down Ctrl while clicking the loop, and then use the graphic manipulators.
  4. Right-click and mouse through the check mark to exit, or double-right-click.
Split Faces
Split a single PolyNURBS cage face.
  1. On the PolyNURBS ribbon, select the Split Faces tool on the Split icon.
  2. Click a point on one edge where you want to split the face.
    Tip: Hold down the Alt key to temporarily disable snaps.
  3. Click a second point on one of the face's other edges to split the face.
Keyboard Shortcuts & Mouse Controls
To Do this Notes
Temporarily disable snaps (PolyNURBS tool) Alt
Change the transparency of the underlying shape (STL or optimization result) Alt+middle mouse scroll
Add to or remove from the selection
Select a loop an enter editing mode
Ctrl
Delete a selected split or loop Delete
Exit tool Right-click and mouse through the check mark to exit, or double-right-click.
