Scheduling Tasks
On the Scheduler tab of the System Settings page, Panopticon Real Time allows scheduling of tasks.
A new scheduled task is added in the list with the properties.
Scheduler Property |
Description |
Run Task |
Manually run scheduled task. |
Create New Task |
Create a new scheduled task. |
Delete Task |
Delete a scheduled task. |
Task Properties |
The task properties include: · Name of the task · Activated status · Type of the scheduled task · Trigger type: Period or CRON · Last user who made an update · Date/Time when the task was created · Date/Time when the task was last ran · Last run result: Success or Failed For failed results, you can hover on the tooltip to view the error. NOTE: The result is not displayed for Extract Data scheduler type.
To create a new task, click
The New Task pane displays that allows you to define the following
tasks:
q Sending of a CSV Data via Email
q Sending of an MS Excel file via Email
q Sending of an HTML Formatted Data via Email
q Sending of an Image file via Email
q Sending of a PDF file via Email
NOTE |
· To allow scheduling of email send outs, Panopticon Real Time must be configured with valid email server information in the Panopticon.properties file located in the AppData folder (e.g., c:\vizserverdata). See Panopticon Real Time Configurations for Email Send Outs and Alerts for instructions. · If any data load fails, such as when the data source is offline, the PDF/Image generation fails as well and an email will not be sent.
