Delete an Application Definition
Delete unwanted application definition.
The Applications panel lists all the application definitions that you have created. You can delete the unwanted application definitions.
  1. Click .
  2. Select App Composer.
    Figure: App Composer
  3. Click next to the application definition that you want to delete.
  4. Click Delete in the context menu.
    The application definition is removed from the list.
