Monitor the status of your jobs, filter the job view, view job details, monitor memory and core utilization, view
a list of job files, or perform job actions.
The Applications panel lists all the application definitions that you have created.
You can edit and save the application definitions.
Click .
Select App Composer.
have created.
Figure: App Composer
Click next to the application definition that you want to
edit.
Note: You can also click on the application definition to edit.
Select Edit in the context menu.
The application definition parameters are displayed in the Compose
panel.
Update the application definition parameters as per your requirement.
Click Save.
Note: The application definitions that you have created are in JSON format and
is stored at /home/$USER/userapps. The System
Administrator can configure the path so that you can edit it in the Text
Viewer.
