Publish a Local Application Definition
Publish a local application definition to the administrator to make it as a global application definition.
The application definition created using the app composer is a local application definition stored in your home directory. The application definitions are stored at /home/$USER/userapps and they are in the JSON format.
The local application definition created can be made available to all the users of Access Web by making a global application.
You must publish your local application definition to the administrator. The administrator will review the application definition and publish it all the users making it a global application definition.
  1. Click .
  2. Select App Composer.
    The Applications panel lists all the application definitions that you have created.
    Figure: App Composer
  3. Select the application definition that you want to publish.
    The application definition parameters are displayed in the Compose panel.
    Review the application definition and edit the application definition if required before publishing the application definition.
  4. Click Publish.
    Publish Application dialog box is displayed.
    Figure: Publish Application
  5. Click Yes.
    The application definition will be published to the administrator and a notification will be displayed.
    The app composer application list of the administrator will get updated with the application definition.
    Note: The administrator can click to view the user who has requested to publish the application definition.
