View a Shared Application Definition
View the shared application definition and save it as a local application definition.
The Applications panel lists all the application definitions that you have created and the shared application definition. You can check the user who has shared the application definition by clicking .
The application definition must be saved locally to view, edit, clone, share, and publish.
  1. Click .
  2. Select App Composer.
    The Applications panel lists all the application definitions that you have created and shared by others.
    Figure: App Composer
  3. Click to view the user who has shared the application definition.
    Note: Delete is the only option that will be available till you save the application definition locally.
  4. Click the shared application definition to view its parameters in the Compose panel and to save the application definition to locally.
    A notification will be displayed.
  5. Click next to the application definition to view the complete options of the application definition.
