Edit 3D Lines
Edit geometric lines.
Delete Lines
Delete required lines from the model.
Combine Lines
Combine two or more lines to form a continuous line.
- Select Combine from the guide bar.
- Left-click to select lines to combine and click Combine.
Split Lines
- Select Split from the guide bar.
- Select a position on a line and click Split.
