Manage E-Points
Use the Manage E-Points tool to modify local system collectors and evaluation points.
For some of the quick risk analysis in order to obtain quick analysis of an E-Line, you may require to modify or reduce the number of evaluation points on E-Lines. Also, there may be cases where you might have to modify the local system collector orientation. Use the Manage E-Points tool to delete connections and rotate Local Coordinate Systems (LCS).
Rotate LCS
Rotate a local coordinate system on an evaluation point.
Delete Connection
Delete connection point(s) along an E-Line.
