HyperWorks
HyperWorks
2022.1
  1. Home
  2. Multibody Modeling
  3. Vehicle Modeling
  4. Full Vehicle Events and Altair Driver
  5. Altair Driver File
    Driver uses the Altair Driver File (ADF) to access all the event parameters in the Solver.
  6. Path Controllers/Lateral Controllers
  • What's New
  • Get Started
  • Video Tutorials
  • Manage Files and Data
  • Sessions and Report Templates
  • Browsers
  • Sketching
  • Geometry
  • FE Geometry
  • Meshing
  • Elements
  • Model Build and Assembly
  • Composites
  • Connectors
  • Morph
  • Skeleton Modeling
  • Design Space
  • Design Explorer
  • Validate
  • Axisymmetry
  • Concept Modeling
  • Crash and Safety
  • Airbag Solutions
  • Aerospace
  • Aeroelasticity
  • Certification
  • Squeak and Rattle Director
  • Panels
  • Results Data
  • Plot Data
  • Multibody Modeling
  • Media Files
  • Tabulate Results
  • Text Files
  • Publishing and Reporting
Index
HyperWorks
2022.1
HyperWorks
  • What's New
    View new features for HyperWorks 2022.1.
  • Get Started
  • Video Tutorials
  • Browsers
  • Sketching
  • Geometry
  • FE Geometry
  • Meshing
  • Elements
  • Composites
  • Connectors
  • Morph
  • Skeleton Modeling
  • Design Space
  • Design Explorer
  • Validate
  • Axisymmetry
  • Concept Modeling
  • Crash and Safety
  • Airbag Solutions
  • Aerospace
  • Aeroelasticity
  • Certification
  • Panels
  • Results Data
  • Plot Data
    • MotionView Overview
      MotionView is a general pre-processor for Multi-body Dynamics.
    • Model Browser
    • MotionView Ribbons
    • MotionView CAD Interfacing
    • Flexible Bodies
      MotionView has many pre-processing and post-processing capabilities with regards to flexible bodies, or flexbodies, for multi-body dynamics models.
    • Preferences Dialog
      From the Preferences dialog, you can access various MotionView options for your model.
    • Vehicle Modeling
      • Build and Analyze Models
      • Vehicle Libraries
      • Components Library
      • Leaf Spring Modeling
      • Road Modeling
      • Tire Modeling
      • Full Vehicle Events and Altair Driver
        • Full Vehicle with Driver
          This section describes how to build events in the full vehicle model with Altair Driver. The new event user interface is supported only for models with Altair Driver. The interface exports .adf and .xml files and submits them to MotionSolve. Files can be edited or updated in the Event Editor. Eighteen event types are supported.
        • Event Types
          This section describes all of the full vehicle events currently supported with Altair Driver. It also describes all of the events and their parameters.
        • Driver Overview
          The Altair Driver is a set of MotionView models and libraries that allows MotionView users to control and script vehicle events.
        • Controllers Library
          Controllers form the core of the driver. The Controller Library has various basic controllers its arsenal to calculate different driver outputs.
        • Additional Altair Driver File Blocks
        • Altair Driver Mathematical Methods
        • Troubleshooting Driver Modeling
        • MotionView Interface
          Driver can be loaded using the Model Wizard of MDLLIB when the Full Vehicle with Driver option is chosen. Driver has some special requirements to interface with the vehicle model. These requirements are resolved automatically if the vehicle model is built using the Full vehicle with advanced driver option in the Model Wizard in MDLLIB.
        • Altair Driver File
          • TeimOrbit Format
          • Altair Driver File Blocks
          • Open Loop Controllers
            Open-loop controllers define vehicle inputs directly without feedback (for example, steering wheel angle vs. time).
          • Path Controllers/Lateral Controllers
            • Feed-forward Steering Controller - Cars & Trucks
            • Lean Angle Controller - Two-wheelers
            • Feed-forward Steering Controller - Two-wheelers
          • Demand Path
          • Longitudinal Controllers
          • Demand Signal
          • Additional Controllers
          • Engine Speed Controller/Gear Shift Controller
      • Road Tools
      • 1D Vehicle System Models
      • Update Model Utility
      • Aerodynamics
    • Tcl/Tk Reference Guide
      Reference material for the HyperWorks Desktop scripting interface which is a set of Tcl/Tk commands.
    • MDL Reference Guide
    • MotionSolve Reference Guide
    • Templex and Math Reference Guide
    • MotionView Python Reference Guide
  • Media Files
  • Tabulate Results
  • Text Files
View All Altair Simulation Help
HyperWorks
HyperWorks
2022.1
  1. Home
  3. Vehicle Modeling
  • What's New
  • Get Started
  • Video Tutorials
  • Browsers
  • Sketching
  • Geometry
  • FE Geometry
  • Meshing
  • Elements
  • Composites
  • Connectors
  • Morph
  • Skeleton Modeling
  • Design Space
  • Design Explorer
  • Validate
  • Axisymmetry
  • Concept Modeling
  • Crash and Safety
  • Airbag Solutions
  • Aerospace
  • Aeroelasticity
  • Certification
  • Panels
  • Results Data
  • Plot Data
  • Media Files
  • Tabulate Results
  • Text Files
Index
