Components Library
- They apply equal but opposite forces on two bodies.
- The force depends on the displacement and velocity of one body relative to the other.
- The parameters, for example stiffness, used to compute the force are stored in a property file that is independent of the MotionView MDL file and the MotionSolve input deck.
- You must supply a property file for each auto entity employed in a MotionView model. A reference (path and name) to the property file is stored in the MotionView MDL file and in the MotionSolve input deck written by MotionView. Currently, only MotionSolve is supported.
- Property files are:
- Text files which may be viewed and edited using any common text editor (TextPad, WordPad, Vim, Emacs, UltraEdit, Notepad++, etc.).
- Compatible with Adams/Car; property files from Adams/Car may be reused with the Auto Entities in MotionView.
- Read by MotionSolve just prior to analysis.
Entity | Function | Features | Uses |
Bump-stop AutoBumpStop
Limit suspension bump or jounce travel. |
Bushing AutoBush
Elastically mount suspension arms, links, sub-frames, engines, gearboxes, etc. to vehicle chassis. |
Frequency Dependent Bushing AutoBushFD
Damper AutoDamper
Dissipate energy stored in springs and damp chassis motions. |
Rebound-stop AutoReboundstop
Limit suspension rebound travel. |
Human Body AutoRider
Model the mass and inertia of a vehicle driver and passengers. |
Spring Air AutoAirSpring
Spring Coil AutoSpring
Tire AutoTire
Generate forces for steering, accelerating, and braking. Isolate the vehicle from small road irregularities. |
