Elements
Table 1. Supported Element Mappings
| Radioss |
OptiStruct |
| /ADMAS |
CONM2 |
| BEAM |
CBEAM |
| BRIC20 |
CHEXA |
| BRICK |
CHEXA, CPENTA, CTETRA |
| PENTA6 |
CPENTA |
| SH3N |
CTRIA3 |
| SHELL |
CQUAD4 |
| SPRING + PROP/SPRING (TYPE 4) |
CBUSH1D |
| SPRING |
CBUSH |
| TETRA4 |
CTETRA |
| TRUSS |
CROD |
Contacts
Table 2. Supported Contact Mappings
| Radioss |
OptiStruct |
| TYPE2 |
TIE |
| /TYPE24 |
CONTACT, AUTO, PCONT, PSURF |
| /TYPE25 |
Loads
Table 3. Supported Load Mappings
| Radioss |
OptiStruct |
| /CLOAD, /FUNCT |
FORCE, DLOAD, TLOAD, TABLED1 |
| /GRAV |
ACCEL2 |
Materials
Table 4. Supported Material Mappings
| Radioss |
OptiStruct |
| MAT/COMPSH (LAW 25) |
MAT9ORT** |
| MAT/ELAST (LAW 1) |
MAT1 |
| MAT/HONEYCOMB (LAW 28) |
MAT9ORT + MATX28* |
| MAT/PLAS_JOHNS (LAW 2) |
MAT1 + MATX02* |
| /MAT/PLAS_TAB |
MAT1, MATS1, TABLEMD |
| MAT/PLAS_TAB (LAW 36) |
MAT1 + MATX36* |
| MAT/VOID (LAW 0) |
MAT1 + MATX0* |
*Only when you click Yes in the RadiossBlock to OptiStruct
conversion tool dialog.
**The values of NU23 and NU31 are set to default values on conversion.
Properties
Table 5. Supported Property Mappings
| Radioss |
OptiStruct |
| PROP/BEAM (TYPE 3) |
PBEAM + PBEAMX* |
| PROP/SH_SANDW (TYPE11) |
PCOMP** |
| PROP/SHELL (TYPE 1) |
PSHELL + PSHELLX* |
| PROP/SOLID (TYPE 14) |
PSOLID + PSOLIDX* |
| /PROP/SPR_BEAM |
PBUSH |
| PROP/SPR_BEAM (TYPE 13) |
PBUSH + PBUSHT |
| PROP/SPR_GENE (TYPE 8) |
PBUSH + PBUSHT |
| PROP/SPR_PUL (TYPE 12) |
PBUSH |
PBUSH1D |
| PROP/TRUSS (TYPE 2) |
PROD |
**Only material, ply thickness, and ply angle is converted.
