Solver Deck Import
Import FE models for supported solver interfaces.
View new features for HyperWorks 2022.1.
The following file types can be read, depending upon the active application.
Create a new file.
Open a file.
Import various file types into the selected client.
Learn about the CAD readers supported by HyperWorks and the options available for importing CAD geometry data.
Overview of how entities are imported.
When an external input translator is used to import data, HyperWorks creates a file for messages in the directory in which the program was started.
An overview of how solver interfaces use the Create components by HyperMesh comments import option.
IDs that are duplicated within element and property groups for the LS-DYNA user profile are supported in HyperWorks.
Learn about importing connector files.
When loading an .hm file, you may receive a warning message depending on the version and solver interface in which the file was last saved.
Load a different solver interface in HyperWorks.
Load command files, scripts, solver template files, preferences, or the Metadata Table.
Save all of the data in your current session.
Export various file types from the selected client to another format.
Most FEA solvers allow you to organize the input deck into separate files and provide a mechanism to include (or refer) these files in the main input deck.
Record a video or take a snapshot of the screen.
Use the Units tool to convert a finite element model from its initial unit system to a new unit system.
ON THIS PAGE
ON THIS PAGE
