MotionSolve
CSE Components
- States Array
- There are two states in the CSE:
Element Description Units 1 Engine Speed [rad/sec] 2 Clutch Slip [rad] - Initial Condition Array
Element Description Units 1 Engine Speed Initial Condition [rad/sec] 2 Clutch Slip Initial Condition [rad] - Input Array
Element Description Units (of Value) 1 Throttle Demand Variable ID [No Units] 2 Clutch Demand Variable ID [No Units] 3 Transmission Speed (at gear box input) Variable ID [rad/sec] 4 Gear Demand Variable ID [No Units] - Output Array
Element Description Units 1 Throttle Position [0-1] 2 Engine Speed [rad/sec] 3 Clutch Slip [rad/sec] 4 Clutch Slip Velocity [rad/sec2] 5 Engine Torque [Model Units] 6 Clutch Torque [Model Units] 7 Throttle Position At Static [0-1]
Sub-Routine Information
Function name (CSE): POWERTRAIN
Dll name: msautoutils.dll
Element | Solver Array [id of] |
1 | 0 |
2 | Clutch Properties Array |
3 | Engine Properties Array |
4 | *Reserved* [Optional] |
Function name (Outputs): POWERTRAIN_REQ
Argument | Solver Array |
1 | 0 |
2 | Request Parameter |
<Reference_String
id = "303001"
label = "Engine Map String"
string = "prop_files/V12_engine_map.pwr"
<Reference_Array
id = "30300300"
label = "Powertrain Input Array"
type = "U"
num_element = "4">
30400100 30400200 30400300 30400400
</Reference_Array>
<Reference_Array
id = "30300400"
label = "Powertrain State Array"
type = "X"
num_element = "1"
<Reference_Array
id = "30300500"
label = "Powertrain Output Array"
type = "Y"
num_element = "1"
<Reference_Array
id = "30300100"
label = "Engine Properties"
type = "IC"
num_element = "6">
4.0000000E+00 8.2000000E+02 3.0300100E+05 2.0000000E+00 1.2000000E+02
1.0000000E+02
</Reference_Array>
<Reference_Array
id = "30300200"
label = "Clutch Properties"
type = "IC"
num_element = "6">
1.0000000E+06 5.0000000E+04 2.0000000E+04 7.5000000E-01 2.5000000E-01
5.0000000E-01
</Reference_Array>
<Reference_Array
id = "30300600"
label = "Powertrain State IC Array"
type = "IC"
num_element = "2">
5.0000000E+02 0.0000000E+00
</Reference_Array>
<Control_StateEqn
id = "303001"
type = "USERSUB"
x_array_id = "30300400"
y_array_id = "30300500"
u_array_id = "30300300"
ic_array_id = "30300600"
num_state = "2"
num_output = "7"
usrsub_param_string = "USER(0,30300200,30300100,0)"
usrsub_dll_name = "msautoutils"
usrsub_fnc_name = "POWERTRAIN"
usrsub_der1_name = "GSEXX"
usrsub_der2_name = "GSEXU"
usrsub_der3_name = "GSEYX"
usrsub_der4_name = "GSEYU"
is_static_hold = "FALSE"
