Assembly Wizard
Model type – “Full vehicle with driver”.
Primary systems for full vehicle with Altair driver model.
Powertrain - The powertrain system available in the library are the
following:
- Manual transmission
- IC Engine Friction Clutch Powertrain.
- Linear Torque Map Powertrain
- Engine that applies torque directly proportional to driver throttle output.
following:
Select a driveline system.
Disk brakes: Apply braking torque on the wheel joint proportional to
the driver brake output.
