Model Identification Tool
The Model Identification Tool, known as MIT, is a profile in HyperGraph for fitting test data from frequency- and amplitude-dependent bushings to analytical models. This tool operates in conjunction with HyperGraph, MotionView, and MotionSolve to provide you with a comprehensive solution for modeling and analysis.
From the Analyze ribbon, Tools tool set, select Model ID Tool from the Tools drop-down menu to access the dialog.
Please click here to view the MIT online help.
