Checking the Model
Use the Check tool to search for any missing references in defined entities or errors in properties.
If errors in the model are detected, it is reported in the message window that is displayed when the check is completed. The types of checks that are conducted are specific to entity types. A model check detects errors such as negative mass for a body and negative diameter for a beam.
