View new features for HyperWorks 2022.1.
MotionView is a general pre-processor for Multi-body Dynamics.
MotionView has many pre-processing and post-processing capabilities with regards to flexible bodies, or flexbodies, for multi-body dynamics models.
From the Preferences dialog, you can access various MotionView options for your model.
When you build front or rear vehicle models using the Model Assembly Wizard you can add analyses using the Analysis Task Wizard that include output requests for Suspension Design Factors (SDFs) which are useful for assessing a suspension’s kinematic and compliance characteristics.
Analysis Tasks create systems and forces or motions which load or move the suspension or full vehicle. Tasks can be modified and saved for reuse in other models. Many common suspension and vehicle tasks are included as part of the library. You can also create and run tasks.
Analysis tasks create systems and forces or motions which load or move the suspension or full vehicle. Tasks can be modified and saved for reuse in other models. Many common suspension and vehicle tasks are included as part of the library. You can also create and run tasks.
A quasi-static simulation during which the left and right suspension is exercised from jounce to rebound and various suspension parameters are calculated.
A quasi-static simulation during which a rolling movement is applied to the suspension and various parameters are calculated.
The coil spring adjuster can be used to adjust a coil spring rate and preload at a suspension position for a particular wheel load and suspension rate.
A quasi-static simulation to study the effect of various load cases applied at the wheel center and tire patch.
A quasi-static simulation during which the suspension is exercised from jounce to rebound and the corresponding spring and axle loads are reported.
Reference material for the HyperWorks Desktop scripting interface which is a set of Tcl/Tk commands.
ON THIS PAGE
ON THIS PAGE
