View new features for HyperWorks 2022.1.
A new workflow emphasizing upfront data loading for standard crash post processing use cases.
Use the Notes tool to label items, describe trends, and relate additional information.
Figure 1. Note Context Menu© 2022 Altair Engineering, Inc. All Rights Reserved.
