In this topic you will learn how to realize, or map, fields.
        Field realization creates pressures and temperature loads, and maps property IDs.
            To map the spatially varying values stored in a field entity to the element and node
            data of the new target mesh, you must realize the field entity.The following types of
                mapping are supported: node temperature loads, node displacement, element pressure,
                element property IDs and indirect thickness, and element material
                orientation.
You can map fields for second order elements, as well.
                Previously, mapping element loads like pressure was not available on second order
                shells or faces with the shape function as the option of interpolation. The shape
                function of first order elements is used to map these values from the
            source.
                In the Model Browser, right-click on the field that you
                    would like to realize and select Realize from the menu.
                In the Field Realization dialog, define realization
                    settings:
                        Using the Entity selector, select the elements or nodes to be
                            realized.
                        Select a field type.
                        Select the type of interpolation to perform: shape function (based on
                            mapping), proximity (based on close point evaluation), or linear
                            interpolation (based on inverse distance).
                        Click Apply.
                Once the field has been realized, the new mapped values can be
                    visualized using contour, or they can be exported to solver decks. When a solver
                    deck is exported, mapped loads will be available on the new mesh.
